Fiat electronic ignition
13 years 4 months before #36713 by manual-mecanica
ELECTRONIC FIAT PUBLISHED BY MANUAL-MECANICA
I have a fiorino with Digiplex 2 ignition system and I would like to adapt an electronic system with module, but apparently the signal generates by the collector is not able to exempt the module, the module is the XM 640. I need an opinion. That module works with a signal generated by the distributor's collector, and I just want to use the one generated by a captor in the crankshaft, which carries 4 teeth.
13 years 4 months before #36741 by manual-mecanica
Manual-Mecanica Response on the Fiat Electronic Light
Hello, the sensor signal is not in the time that nesecitas and is a different signal to the one that triggers the module q must be a hall effect.
You should place a type 1.4 or 1.6 engine distributor traction by the camshaft to which you must make a slot for the distributor's drag jack. I hope it serves you !!!!!
Daniel Lopez Gral Injaction Roca Rio Negro. Argentina
13 years 4 months before #36776 by manual-mecanica
Thank you for the distributor I was watching them and it turns out that the Fiorino retains the block of 147 and brings the coupling for the distributor, good data, but the module served me, he throws good chipa, but I will have to mount a crburer, because the injection needed the old computer, but for them to know it is much cheaper that module $ 10,000 (US $ 20) than a new computer.
