Jetta 98 ​​2.0
13 years 4 months before #36676 by manual-mecanica
Jetta 98 ​​2.0 Published by Manual-Mecanica
Someone can help I have a Jetta 98 ​​2.0 liters spends gasoline, it is already changing pressure regulator, refrigerant temperature sensor, injectors etc The last change in it was that the catalytic converter was eliminated but it continues to be perceived in the slight smell of raw gasoline spark
plug
13 years 4 months before #36678 by manual-mecanica
Manual-Mecanica Answer on the Re: Jetta 98 ​​2.0
Hello AMI, in reality many are pounded with the VW Jetta and Golf A3 even I buy them by K they say they cannot leave them well, I fix them and sell them: P .
Well, first of all, the regulator is very rare k is damaged, the injectors only have a 4000 RAM as a case, if they are VW, nothing happens, your problem is in relay 30 or in the bulb of temp, and one more thing the spark plugs of more than one electrode are not good for those models (A3) are better the spark plugs of an electrode calibrated in 32 that can also do so. Those are the most common of no kedar, with the scanner check the values ​​of MAF or MAP and replace. Good luck my friend.
