Transmission Ford Explorer 97 Strange Failure
13 years 5 months before #35939 by manual-mecanica
Transmission Ford Explorer 97 Strange Failure Published by Manual-Mecanica
Ford Explorer 1997
Motor 4.0 SHOC
Automatic Transmission 5R55E
4x2 Traction
Failure: When I use the vehicle in short distances, I turn it off and then I turn on and try to start in D does not grab the speed, now I put it in reverse enters without problems, I put it in 2 and enter without problems and in 1 enters without problems fence all normal but the D does not enter, after a while with the vehicle off the vehicle. (Road The Transmission does not present this problem. When the vehicle is freshly lit the D enters without problems and works without any fault.
Tests or arrangements performed: the fluid of the transmission is changed (oil) already changes the transmission oil filter the level of the fluid is correct. The front oil radiator
problems … .
13 years 4 months before #36240 by manual-mecanica
Manual-Mecanica Response on the Re: Transmission Ford Explorer 97 Strange Failure
You must make the transmission over, it is heated because the bushings are already worn, you must also have internal lubrication problems, you must also have worn records, I also recommend that you change or rebuild the torque convert, better known as hydraulic cluth.
