Scanner elm327 does not scan me
13 years 5 months before #35935 by manual-mecanica
Manual-Mecanica Answer on the Re: scanner elm327 does not scan me
Well my elm327 is with cable I will try in the port com4 and I will tell you if it worked me hopefully it works
13 years 5 months before #35937 by manual-mecanica
to the mechanical friend876 ......... first you need to buy elm327 which is a cable that connects to the OBD2 ports of the vehicle and the other end you connect to the PC ... but in particular I have been testing and I have not been able to shine any vehicle ... the advantage is ma $ cheap that the scanner and gives the data in real time ... for now I do not advise you because it has not served me in particular ...
.... also the place where I asked for it ...... www.sears.com/es/us/brainydeal-elm327-v1...6307252202p?prdno=22
13 years 5 months before #35952 by manual-mecanica
In the description of the product it says that it does not include Windows 7 perhaps that is your problem. Mine is a Bluetooth link and it works well for me, only sometimes it gives me problems that there is not the communication port and I have to restart the machine but it is not very often, the rest it works well for me even in the vehicles with Can Can system
