Change xenon bulb in a lagoon II
13 years 5 months before #34412 by manual-mecanica
Change xenon bulb in a lagoon II published by Manual-Mecanica
Good evening
if someone can help me
I have a 2004 1.9DCI lagoon
someone could indicate the steps to change the xenon bulb on the driver's side
thank you and greetings
13 years 5 months before #34660 by manual-mecanica
Manual-Mecanica Answer on the Re: Change xenon bulb in a lagoon II
Hello Joaquintomas.
There are, as in the rest of the things, 2 ways: 1 the easy and 2 the difficult. The bad thing is that I don't know which one, if 1 or 2.
(1 or 2, I don't know!) I have changed the lamp on the left side several times. It is not difficult, it takes 10 or 15 minutes in total, but it depends on your manual skill. You will need to remove the battery lid, remove, at least a little the battery if you do not want to remove it from the car, remove the cable connector that passes between the battery and the fin, and loosen the air inlet tube to the filter. With that you already have access to the lighthouse. You have to first get the ballast and, finally, you can get the happy Xenon bulb.
(2 or 1, I have already told you ...) This is the official Renault system, and as such I describe it. It takes much longer ... but sometimes the dress me slowly, that I am in a hurry ... you have to value it. I also attach a file to see it better.
You have to remove:
-The lower protection under the engine,
-la Calandra,
-The front bumper,
-The two upper guides (under the lighthouse, between body and bumper),
-quite the screws that hold the lighthouse plus a plastic clip.
With that you already have the lighthouse in your hand and you can change the lamp.
Luck!!
13 years 5 months before #34665 by manual-mecanica
Thank you proof over
another query if you can solve it to me:
I put the air conditioner, the air conditioning and by the air dispensors nothing this can be because the motorcycle fan of the spoils is broken or it is due to another circumstance.
Anyway thanks and greetings
13 years 5 months before #34709 by manual-mecanica
Well, you don't give me many data. Do the fans sound even if it is short? I would start looking at the antipolen filter, which is inside the glove compartment. When it is very dirty, no air comes out of the shots. Are the air conditioner lights on? Does the auto/manual switching work? The speed indicator of ventilation engines moves?
Greetings and luck.
13 years 5 months before #34764 by manual-mecanica
Good afternoon:
When I give the climate to the air conditioning the indicator begin to leave the rallitas in the indicator to the maximum level but by the air distributors nothing comes out. I stop manual until all the rallitas of the air conditioner come out and nothing comes out either nothing has told me a friend who could be the interior fan motorcycle.
Abusing some of your wisdom. Yesterday the battery disconnects and when I have replaced it it turns out that the window now I have to raise and go down to impulses when before changing the battery I climbed when it gave the lunas everything followed and the same to go down. I have already configured the radio.
Thanks again and greetings
