My Logan accelerates too much
13 years 6 months before #34326 by manual-mecanica
My Logan accelerates too published by Manual-Mecanica
Hello Friends of the Forum, my Renault Logan accelerates and reaches up to 30000 rpm, when I turn on the a/a it goes to minimal and almost turned off, I changed spark plugs, spark plug wires, gas and air filter, injector cleaning, IAC valve (generic) the original is not achieved, it was scanned and according to the technic Damaged and does not send signal to the IAC and TPS, after all this it still accelerates now it has dropped until the 20,000 rpm and continues almost until it goes out when I turn on the A/A, greetings and thanks in advance from here from Venezuela
13 years 6 months before #34329 by manual-mecanica
Manual-Mecanica Answer on the Re: My Logan accelerates too much
Good evening Friend Your problem is in an empty hose or an air input if it were an electrical or sensor problem or ECU The scanner would throw it more when the computer is bad by some integrated trannstor or etc. The scanner does not throw anything I recommend you take it to a person who really knows and apologized but here in Venezuela it is little that you know of the mechanics. The majority are changing pieces. Trust of a friend your self but your problem is air entrance or a bad emptiness hose that this game
