Ignition problem
13 years 7 months before #33866 by manual-mecanica
Ignition problem published by Manual-Mecanica
Good morning everyone
when I want to turn on the cold vehicle in the morning a noise like chain is heard when the vehicle key viro. To be due to this noise. It will be that the chain that is inside the starter is lazy or loose. My vehicle is an Hyundai Accent 2003
I appreciate your comments
13 years 7 months before #33867 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition problem
Well late that engine does not wear a chain is a strap and I doubt that it is a strap can be worn whales because a luggage will lose oil during the night parked and when it turns it out it sounds as if it had a chain inside that is xq the oil taquets are downloaded in the transmission of the day do not usually sound xq the engine is on I recommend you change tales and hammer In the links
13 years 7 months before #33895 by manual-mecanica
Thank you very much estimated
13 years 7 months before #33899 by manual-mecanica
Do you not change the oil?
13 years 7 months before #33956 by manual-mecanica
It may be that your vehicle are changing the synthetic oil ... change for a good oil .....
