maintenance or maintenance light Chevrolet Cruze
13 years 7 months before #33705 by manual-mecanica
Hi, I have a cruze chvrolet and has the light or maintenance light on and I don't know how to turn it off and what with the simple scanner, can you know how can this light be reset?
13 years 7 months before #33707 by manual-mecanica
Put on the switch
13 years 7 months before #33739 by manual-mecanica
Switch on is first contact only dashboard lights?
The other tells me code 92 I think both fault witnesses (maintenance key) will be erased and what says error 92 ??
13 years 7 months before #33743 by manual-mecanica
Outside you try on it 3 times and 5 and I did not turn off it only I got the scanner (KTS 550) if you cannot tread the pedal it will only be cn scanner in this vehicle
13 years 7 months before #33751 by manual-mecanica
I have tried putting it, I will carry it without starting the vehicle stepping thoroughly and release the accelerator 5 times then the key to off and when putting the contact already reset. I have done it in Avalanch, Colorado and Cobalt. If you do not take the key to OFF after pressing 5 times the accelerator does not restart.
