Dodge 91 Automatic Transmission
13 years 7 months before - 13 years 7 months before #33681 by manual-mecanica
Dodge 91 Automatic Transmission Published by Manual-Mecanica
It is a Dodge UP Up 91. From KE some seals changed to the automatic transmission to eliminate oil leaks, the changes happen very fast and the pick up does not develop the speed that should and apart it spends more fuel, before Ke will kitar the transmission the pick up the changes came very well they did not do that work and kedo did that work. As and in what part of the transmission the changes are calibrated, I would appreciate it to guide me how to do it or do. thank you
Last edition: 13 years 7 months before by .
13 years 7 months before #33684 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Transmission Dodge 91
It would have to know if it is transmission Mitsubishi or Chrisler because they are different. One I think it is cable and the other is of a shrimp
13 years 7 months before #33709 by manual-mecanica
I think Ke is Crisler and rod, it carries it from the carburetor to the transmission
13 years 7 months before #33712 by manual-mecanica
That transmission carries an acceleration valve, most likely this badly calibrated.
13 years 7 months before #33717 by manual-mecanica
These types of transmissions are calibrate by the overmarcha, most likely that they have been disconnected in some models and in other cable it is activated the KickDown valve (or overwhelon) you have to check if it is not release That caliber is a guarantee of him I hope this information has served you Greetings from Saltillo Coahuila Mexico.
