RENAULT SCENIC 1.9DCI 120CV 2003
13 years 7 months before #33440 by manual-mecanica
RENAULT SCENIC 1.9DCI 120CV 2003 Published by Manual-Mecanica
HELLO. I have a Renault Scenic 1.9 DCI 120CV of 2003. In the picture I am an error that the automatic lighting system does not work. Indeed it doesn't work. I know that a black round sensor for automatic lighting and rain sensor that does not work under the rearview is. I put another and still work. In addition, the first speed of the windshield wiper instead of making it intermittent as I think it should be followed as the second. (Unless it is programmed as the windows). I have noticed where the sensor goes and does not have or has very little gel. Can it be why you don't have gel? Can it be a malfunction of a switchboard? I have it inhaled and the driver's door should also be opened just to pull the handle and it does not open. Open all the car except that door. Can it be a program? Everything else works very well. Is there any programming manual of that model?
13 years 7 months before #33491 by manual-mecanica
Manual-Mecanica Response on the Renault Scenic 1.9DCI 120CV 2003
Hello friend for what you comment it seems that you have a problem with the UCH that goes above the fuse box she tasted all the advisories to see that it does not unkly have to scan it with the brand if it were so or if they do not change it but they must still program ...
