TOYOTA RAV4 05 '2.0 DIESEL MOTOR D4D
13 years 8 months before #33203 by manual-mecanica
TOYOTA RAV4 05 'Motor 2.0 DIESEL D4D Published by Manual-Mecanica
My RAV4 truck, since Buy has the characteristic that when starting cold or temperature the engine turns a lot. I do not know if it is normal or I must make some part especially. Scent comments.
SLDS.
13 years 8 months before #33204 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Rav4 05 '2.0 Diesel D4D Motor
They can be the injectors that are somewhat clogged
13 years 8 months before #33207 by manual-mecanica
But the injectors work all the time, not only at the start ... that is, it has no problem in acceleration, power, does not smoke, etc.
13 years 8 months before #33253 by manual-mecanica
Hi Roderick.
It seems to me that if you should have a little smoke when the fault occurs and that you have not noticed because it is only at the start. If the smoke is white, it is due to an excess of condensation and is water vapor, which disappears to the second or third working time, if gray it can be an injector with low fuel delivery pressure and that normalizes by accelerating and acquiring its normal working temperature, in none of the cases it is serious, luck.
Miguel
