URGENT HELP Opel Corsa B Combo
13 years 8 months before #32528 by manual-mecanica
URGENT HELP OPEL CORSA B COMBO PUBLISHED BY MANUAL-MANICA
Hello, how are you, well, I have a serious problem. It happens that I am trying to solve a problem with Chevrolet Combo Osa an Opel Corsa B, 1.4 CC, year 1999. It happens that the car came with a problem of excess smell of fuel in the bone game was delayed in starting, but of a few start starts, we have changed the pressure regulator, the crankshaft position sensor, the coland, the oxygen, the injectors were cleaned and changed spark plugs and the light But the car does not want to start now, I have given several starts and does not want to start, and I need urgent help please. I await answers .chaoooo greetings to all.
13 years 8 months before #32532 by manual-mecanica
Manual-Mecanica Answer on the Re: urgent help Opel Corsa B Combo
Greetings Iquiqueño, first of all check first if there is a spark and injection in their respective components (checking sparkling in the spark plug and placing witness in injectors), the following and recommended is to scan the vehicle to see what codes it throws, an excess of fuel is indication of failure in any sensor (failure mode). Check that and tell us.
13 years 8 months before #32539 by manual-mecanica
Hello, how are you, well, I answer you, the car has a spark, it has a good injection pulse since it performs a test watching if the pulses are fast or slow, since that would indicate some extension in the intention, but I check them and the pulses are well, the point is fine, I have a concern referring to the computer it is likely that it has been blocked that I have tried everything and nothing happens to me, and it does not happen. They have tried Scanare and have not had good results, I mean it is impossible Win some lucas hahaha, well take care of thanks for the attention Chaooo
13 years 8 months before #32551 by manual-mecanica
Greetings, it depends on your location, it is difficult to scan this vehicle brand, now that this blocked I do not believe, since the first symptom is not to have a spark and/or injection, there are even models that cancel the starter engine, it is always accompanied by an indication on the board of most times, if they have not managed to connect the scanner, it can indicate damage to the ECU.
13 years 8 months before #32557 by manual-mecanica
As well as the engine compression .......
how many km has ....
a greeting
