T-Belt
13 years 8 months before #31432 by manual-mecanica
T-Belt posted by Manual-Mecanica
Someone could tell me how I can turn off the indicator of the T-Belt box, of a Toyota Land Cruiser Colorado/Prado of 2001, the engine is 1kd-FTV.
Thank you and greetings to all the foreros.
13 years 7 months before #31495 by manual-mecanica
Manual-Mecanica Answer on the Re: T-B-
Hello, if it is a model with a digital box this mode should work. If it is a model with analog box you have to remove the box and lace canviar a tornyl that is at the rear of the box. Greetings
13 years 7 months before #31511 by manual-mecanica
Thank you, ......... is the digital one, as soon as I try it, I warn you if it worked.
Greetings and thanks once again
13 years 7 months before #31584 by manual-mecanica
Hi Jector, it worked correctly, I already managed to turn off the T-Belt witness, once again thanks :)
