consultation..
13 years 10 months before #30725 by manual-mecanica
Query .. Published by Manual-Mecanica
Good evening I address you to ask you for help ... I have a fault with my 2006 Power party which is presenting a fault, the gasoline engine is flooding me that it was the injectors, I bought them and nothing is still the failure when I turn on the white smoke boot with a full gasoline
13 years 10 months before #30727 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation ..
Hello, you can have a problem with your gasoline pressure regulator
13 years 10 months before #30728 by manual-mecanica
hi, friend.
If the gasoline pressure regulator is located, within the dynamic camera, it is possible that it is very bad leaving gasoline and is falling into the carter, if it is for the fura of the camera, it may be for the empty manquera, in this case the emission of egases, good luck, is considerably increased considerably.
13 years 10 months before #30730 by manual-mecanica
Hello, how about good night thanks for your answer ... a question this regulator how do I identify?
13 years 10 months before #30732 by manual-mecanica
Follow the entrance line to the injectors rail, at the end of the rail you find a valve, with a constant emptiness that goes to the dynamic or multiple camera of admission.
