Ford transit clutch help
13 years 11 months before #30035 by manual-mecanica
Ford Transit clutch help by manual -mecanica
Hello happy people to all ... I am new in this forum and between looking for a clutch solution which happens following the following ...
I changed the bomb because I had to pyar the pedal many times to answer me. I change the bomb and it still does the same, the problem is that I walk and I want to make a change and I cannot since I have to pump it to hook again ... what can be ... or how can I do it to solve it
13 years 11 months before #30037 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Transit PLEASE CLUTCH
Hello, the truth is that I get a little green with hydraulic clutches. Those who have run normally mechanical (with cable). You say that you have to pump a lot for the clutch to act, being hydraulic I would tell you that perhaps the hydraulic circuit is not well bleeding, (you have air in the circuit and that is why it does not work, it happens the same with the brakes). I would check if you have enough fluid in the circuit, or if there is any leakage in it. Another thing, is the clutch hard when you step on it? I hope I have helped you. All the best.
13 years 11 months before #30038 by manual-mecanica
Hello good. Thanks for the resp. If so, I have to pump the pedal to act a lot to act, Liquid has the suffering and a little more, I tmb I thought it can be air, the subject that I do not know where the potharm is, the pedal when it does not act is super soft, you give yourself that it is not working, then you start pumping and starts to get harder and it is there it works well but for little time .. thanks ..
13 years 11 months before #30040 by manual-mecanica
For me it looks like the circuit, or is not well bleeding, or loses you somewhere. I would start looking for your transit's workshop manual, (look on this website, there are a lot of manuals, and surely you find it) and I would study the entire clutch well, surely there comes the location of the gum, or some explanation of how to bleed the circuit. If after that the problem persists, then I don't know. Let's see if someone who is more familiar with your van Read your ad and tell you. Luck.
13 years 11 months before #30042 by manual-mecanica
Thank you Legolas ... your answer is the same since I find that I am not alone in my opinion haha ​​... now I will look for the manual and we see what happens ... Thank you very much ..
