MITSUBISHI ECLIPSE GS Motor 4G63
13 years 11 months before #29429 by manual-mecanica
Mitsubishi Eclipse GS Motor 4G63 Published by Manual-Mecanica
I have a problem with a mitsubishi engine. Electrovantilers are constantly lit and the temperature always keeps in the middle evaporates water approx 250 ml a day without much use grabs the cooling system compression and the cooling system is two days ago.
13 years 11 months before #29537 by manual-mecanica
Manual-Mecanica Answer on the Re: Mitsubishi Eclipse GS Motor 4G63
If you pass the water to the oil, you will miss the blanket packaging you have to dismant
