Help with a Ford Focus
13 years 10 months before #29077 by manual-mecanica
Help with a Ford Focus published by Manual-Mecanica
I have a problem with a Ford Focus 2001 2.0 dohc I change the motor support but now it no longer turns on if there is a spark of current and tmbien gasoline pressure is not ak it should be urged
13 years 10 months before - 13 years 10 months before #29098 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with a Ford Focus
Hello, look for the vehicle workshop manual because in the Fords they have a sensor on the left side of the driver in the feet sector that paralyzes the vehicle or if you have alarm. LUCK.
Latest edition: 13 years 10 months before by .
13 years 10 months before #29100 by manual-mecanica
Do you say where is the gasoline pump button? I already reset it and nothing but thank you very much for your help it is attacked by heart
13 years 10 months before #29116 by manual-mecanica
Hello, how are you
when we work electronic cars, we must often resort to the only tool that will give us this data and parameters the scanner
I suggest you give a scan to know the values ​​and the possible fault code.
greetings
13 years 10 months before #29146 by manual-mecanica
If we put the scanner but mark connection error, already find the problem ... the problem is the time band and a tensioner broken what happens that the motor support is broken and by logic the engine fell, thank you for your help
