CODE P1580 OBDII BMW Mod 99
14 years 6 days before #28765 by manual-mecanica
CODE P1580 OBDII BMW Mod 99 Published by Manual-Mecanica
I have problems with a BMW Modl-99 with Code OBDII P1580 Code says that accelerator body is mechanically attached. This system is cable, the engine is normally well minimal but when it is accelerated, it begins to make cuts of injection and there is power. I already checked the gas prection and this normal one in 50PSI Functs Clean Ultrasound, I changed the full accelerator body and the problem insists I check the cable harness is OK, if someone with experience can give me a hand is appreciated beforehand ...
13 years 11 months before #29431 by manual-mecanica
Manual-Mecanica Response on the Re: Code P1580 OBDII BMW Mod 99
According to a codes table that you can decarge is P 1580 mechanically stuck butterfly valve. Greetings and luck
