Bubbles in antifreeze
14 years 3 weeks before #28104 by manual-mecanica
Bubbles in antifreeze deposit published by Manual-Mecanica
How about friends, I have a Stratus 2.4L 2001. BUBUJEA the refrigerant deposit. The engine has no failure or heated. Why bubble in the deposit? My email . Thanks for your help.
14 years 3 weeks before #28106 by manual-mecanica
Manual-Mecanica response on the re: bubbles in antifreeze deposit
It looks like a cylinder head, doesn't they lose antifreeze? Does the antifreeze have spots? I will have the oil filling plug and see if it has white pasta and in the oil rod too.
14 years 3 weeks before #28107 by manual-mecanica
I thank you for your attention friend. I reviewed both in the deposit and in the oil ball if they have indications of oil or water respectively, but they are fine. Do not emit white smoke by the exhaust and compression is correct (128 psi even), it does not lose power nor does it have fault codes. The car works well, but it worries me the bubbles that it takes in the tank when it is hot. Nor has antifreeze leaks.
14 years 3 weeks before #28113 by manual-mecanica
I do not know the engine that is exactly, but I limit you the deposit of the anticonjelante? Or do you only see bubbles, will not carry a fine tube of entry to the deposit to recirculate the liquid, do you have the level in cold or it is low?
14 years 3 weeks before #28121 by manual-mecanica
Hello lucogo ... Look there if you have no loss in the water circuit where the circuit could enter the circuit ... then I would throw myself to look at the tapa's lid that there the air valve does not open and accumulates you a lot of pressure, better check the two tapas ... luck !!
