Do not turn on hot
14 years 1 month before #26990 by manual-mecanica
It does not turn on hot published by Manual-Mecanica
Hello everyone, I have a problem with my golfite 91, to see if you can help me? In cold I turn on to the touch, but after walking for a while I turn it off and no longer turns a click, I wait for a while and turn on again, I already changed ignition coil and I put a resistance, I changed the monkey, the cables and disruption cover and the starter engine is one hundred, some idea that it can be, thanks ..
14 years 1 month before #26991 by manual-mecanica
Manual-Mecanica Response on the Re: Do not turn on hot
The temperature is normal ...? And incidentally tell if you have CNG?
14 years 1 month before #26992 by manual-mecanica
The temperature is normal and because it is carburetor, it is not the truth that it is the CNG,
14 years 1 month before #26994 by manual-mecanica
Check out the starting engine when they are hot spent, only the solenoid is heard
14 years 1 month before #27729 by manual-mecanica
Compa Preblema is the starting bike
