Renault Scenic 1.9 dci 120cv
14 years 1 month before #26943 by manual-mecanica
Renault Scenic 1.9 DCI 120CV published by Manual-Mecanica
Hello to see if they can help me here, I have a Scenic and I turn on me from time to time in the checkery injection, and lose power, stop it and start it again and take it away, I have already changed the turbo valve, but it remains the same.
Could you help me?
Thank you.
14 years 1 month before #26944 by manual-mecanica
Manual-Mecanica Response on the Renault Scenic 1.9 DCI 120CV
Hello, you would see the fault code that appears. But in F9Q engines it is frequent damage in the injectors since you say that the valve replaced, another fault would be the depression valve that is just winged with that of the turbo and this but opens cannot act that of the turbo greetings
14 years 1 month before #26947 by manual-mecanica
Thank you, I will tell the mechanic.
