Diesel delicious spark plugs control 2.8
14 years 1 month before #26748 by manual-mecanica
Diesel Diesel Delica Dismay Heating Control Published by Manual-Mecanica
Hello friends: I live in a area where it is difficult to buy spare parts for delicious 2.8 Space Gear Year 1994. Weeks ago the alternator burned as a result of the failure of the control of the tax spark plugs. Good; Arranged the alternator, Choco with the problem of control that is not found throughout the city (or second -hand) have sold me one of Hyunday 100, Model Control Glow, but without the connection scheme that is different from the offense of the Criminal.
My question is: how could I know if I can use this control, and where to find the appropriate scheme?
I will be very grateful and the environment too, because I let out terrible smoke until about two-two minutes. See you soon. ROSSO.
14 years 1 month before #26750 by manual-mecanica
Manual-Mecanica Response On the Re: Control Heating Diesel Delica Spark plugs 2,8
Determine the direct current cable in the male connector and in the female connector you have an output that connects to the spark plugs you have a contact current that outskin to the relay may not be the same but it has to have the same amount of cables if you manage to determine those two cables you have to have 3 cables plus one exit of relay mass the other witness light and the third
14 years 1 month before #26769 by manual-mecanica
Thanks Collega, but there is a question: there are the two thick cables (red battery and green spark plugs) but there are 7 more contacts! Of these, there are 3 that are even (two to two) plus one that is alone. I do not have a tester to try to determine what you inform me, so I will have to look for someone who has a hyundai? (The letters is erased ...)
I will try your information. You don't know what your email is appreciated. Kind regards. ROSSO
