Fiat Stilo Ashr Esr Cnexion Floja, Help!
14 years 2 months before #26145 by manual-mecanica
Fiat Stilo Ashr Esr Cnexion Floja, Help! Posted by manual-mecanica
Hi, I have a Fiat Stilo 1.6 16V of the year 2001 and when I go, I suddenly stop and put me on the computer asr asr Floy connection. Please help me !!!! Thanks in advance and cordial greetings!
14 years 2 months before - 14 years 2 months before #26159 by manual-mecanica
Hello, you see the dough that goes from the negative of the battery to the chassis this loose check that is usually a metal mesh
Latest edition: 14 years 2 months before by .
14 years 2 months before #26170 by manual-mecanica
Thank you for answering, the check -up to see how it presents corrosion or something.
Greetings
14 years 2 months before #26190 by manual-mecanica
The partner German is correct if the failure persists, verifies that the vain engine switch does not have corrosion, due to failure of bad contacaco, if it has corrosion you could disconnect-the it and clean connectors I centraliat with cleaning cleaning, I could go well as not, if it is not the case to change the engine vain engine. Before that, you can verify battery, also appear if the quadro instruments the clock of the hour does not blink if it is so a failure of retention of energy of the battery.
14 years 2 months before #26193 by manual-mecanica
Well, the case is that the screen is times that it looks like a bit blurred, that happens to me when the sun gives it. The battery is changed two months ago, the unic of the dough, now I have it in a friend's workshop, to see what he tells me. Thanks for answering!
