My hot chevy
14 years 3 weeks before #26039 by manual-mecanica
My hot chevy published by Manual-Mecanica
My 2003 Chevy is apparently heated without reason, the early sensor has already been changed several times, the equal, radiator pump, and they aren't found that it is, any idea?
14 years 3 weeks before - 14 years 3 weeks before #26040 by manual-mecanica
Manual-Mecanica Answer on the Re: My hot chevy
:) Hello I ask if you have already changed the thermostat and if you have
revived the thermal range of the spark plugs and the ignition point Salu222
Latest edition: 14 years 3 weeks earlier by .
14 years 3 weeks before #26047 by manual-mecanica
No, the range of spark plugs, I suppose in the information of the spark plugs, but and the ignition point? That as? I really confess it to 3 mechanics but I have been the same for a long time, hopefully I can check it myself, so I learn.
14 years 3 weeks before #26048 by manual-mecanica
Because I do not check the engine compression, the button of the butt is broken and you are fleeing you
14 years 2 weeks before #26182 by manual-mecanica
What state are you, maybe I can check it personally, I guarantee a correct diagnosis
