Help with beetle cable branch
14 years 2 months before - 14 years 2 months before #25897 by manual-mecanica
Help with beetle cable branch published by Manual-Mecanica
Hello, which I am new in the forum ... friends I do electricity from scratch to my beetle (vocho) I would like to help me ... in the positive of the battery how many cables can I grab as maximum and minimum (at the start) I bone in the priesting branch ... are well 5? Or it is a lot ... it is positive for suichera, thick cable to lights of lights, one to the rifle, and additional 2 in case ... It's a lot of thanks friends
Latest edition: 14 years 2 months before by .
14 years 2 months before #25908 by manual-mecanica
Manual-Mecanica response on the Re: Help with beetle cable branch
Hello, first of all, the amount of cables does not influence but the load of each one (amperage per consounding hour) with this I mean that it is more dangerous to put 2 thick cables to two malacates that will consume a lot to put 15 finite cables to feed some girls or many LEDs.
In the battery the maximum will give you the amount that enter in the terminal and the capacity in ampers that this support:) and in the donkey, if you connect them in the donkey terminal you can put a few that do not cosmman load when starting, tries not to go from 15 or 20 ampers.
I hope it has been clear in the ezplication, greetings and luck
