CHIP LOCATION 93C76
14 years 3 months before - 14 years 3 months before #25178 by manual-mecanica
CIP 93C76 location published by Manual-Mecanica
Hello friends, I am in a problem, I cannot locate the 93C76 chip on the board of a Grand Cherokee year 2006, it is an 8 -legged chip. Thanks in advance.
14 years 3 months before #25180 by manual-mecanica
Manual-Mecanica Response on the Re: Location Chip 93c76
Caroqui, how are such a pleasure in greeting it, Cherokee boards there are several versions, as you say you must look for 8 -pin chip either on the back side, or if you would not have to disassemble the board to look for it from the side inside the plate, which is where they usually put them. And finally if it is not anywhere in the board, it means that the kilo comes in the micro. Search the link www.tachosoft.com where all vehicles are.
14 years 3 months before #25369 by manual-mecanica
Hi, friends 93C76 chip of the graduate Cherokee 2006 is located on the inner side of the panel just below the main white connector you have to be fly because there are two together and they are similar on 93c76 it has one point and the other does not and you have to be very careful when the needles disassemble the needles the nomenclature of the chip is not the same I hope my help serves you. Ulysses
