Jeep Grand Cheroke does not turn on
14 years 5 months before #23318 by manual-mecanica
Jeep Grand Cheroke does not turn on published by Manual-Mecanica
He is 5 months, I put a new battery and now light for two seconds and goes out, the problem is with the alarm but I do not have control, I could tell me some way to disable it the model is 1994 I think it is 4.8 I am urgently urged beforehand thanks.
14 years 5 months before #23392 by manual-mecanica
Manual-Mecanica Response on the Re: Jeep Grand Cheroke does not turn on
Proba taking the fuse of 30 the third on the side of the right of the engine rifle for a minute, place it again in contact later boot
14 years 5 months before #23454 by manual-mecanica
If the alarm is activated and the bugle sounds intermittently. Try by passing the key when it is playing through the pilot's door, so it is deactivated.
14 years 4 months before #23830 by manual-mecanica
I already solved it thanks for his answer The Jeep on and turned off at 5 seconds, the solution was to open and close the back door several times, at this door the switch brings to disable the alarm since it cut the current and went out, thanks.
