Ford Windstar
14 years 6 months before #21655 by manual-mecanica
Ford Windstar published by Manual-Mecanica
Greetings to all, I have a Ford Windstar 99, which did not turn on the foci of the board (only the rooms) disarms to revive and had a molten focus but when assembling it they still do not turn on and the meters no longer works (velocimeter, tacometer, temperature, gasoline, horometro) looking for information but there is only Windstar 2001 and the connectors do not correspond.
If someone has any information or that I give me a north to solve it.
Thank you beforehand.
14 years 6 months before #21661 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Windstar
I do not know that car well because here it is not sold. I would review the fuses first and then if it has a potentiometer to lower the intensity of the lights of the painting, (bridge the potentiometer to check it). As the indicators no longer work if the fuses are fine check the connectors of the indicators box if they are well connected. A greeting.
14 years 6 months before #21682 by manual-mecanica
In the lower part of the steering wheel it carries a relaxy box check the one that says Instrumental Panel, if it is well check the switch that lights the lights.
14 years 6 months before #21718 by manual-mecanica
Greetings and thanks for your answers.
Already check the fuses and swhaces being fine. Disarma the board and has two electronic cards in one find two damaged (burned) elements but the data is not seen I put a voltage regulator and already turn on the spotlights but do not go out, I think it is a SCR or transistor. Will they have schematic diagrams of the board?
14 years 6 months before #21850 by manual-mecanica
Do not rely on the connectors, you already have two problems are simple if you pay attention, your rooms get a constant negative, when putting Czech rooms that the positive arrives and if it does not reach it it is your swicht of lights now to your devices three cables reach each one, a constant negative, a signal and a positive when opening the swicht if Czech fuse does not arrive, and if not, it is your body control.
