Ford F-350 V8 7.3
14 years 2 months before #20965 by manual-mecanica
Ford F-350 V8 7.3 Published by Manual-Mecanica
The map cannot be shown, you have not yet specified a location.
Gentlemen, I turn to you. To see if you can help me, I have a 7.3 cc Navistar V8 engine and presents a fault that at the time of activating the turbo stops throwing that is to say totally loses its strength, the following PO603 error codes that would be internal control mod kam error, then my question is, how do I solve it that is the kam?
thank you
14 years 2 months before #20968 by manual-mecanica
Manual-Mecanica Response on the Re: Ford F-350 V8 7.3
The PO603 code indicates that the curator lost its power or land (example battery disconnected) if it were the reason you will only have to handle the vehicle although it fails for about 15 km so that the operation relens. If the code persists the code checks the currents or lands that must reach the PCM and contemplate that they can be cut intermittently. info.SALUDOS
COOLFORATION OF: TECHNOMOTORES
14 years 2 months before #20994 by manual-mecanica
Estimated, check the food and land and the problem persists now not the body's lights turn on and those of the board and the terminals are in very poor condition especially those that connect to the negative in both batteries, can that be the problem?
Thanks for the help
14 years 2 months before #21259 by manual-mecanica
I think the best thing to go x parts is to clean the terminals and if the gazas are damaged to change them. X You can start the solution to the problem. SLDS
14 years 1 month before #21495 by manual-mecanica
I esteem, I found the problem there was a land that goes directly to the computer that was loose and also the starting engine was making land when repairing what the truck is left as a plane.
Thanks for the tips
