Help with the modification of an engine
14 years 7 months before #20808 by manual-mecanica
Help with the modification of an engine published by Manual-Mecanica
Boys I need help to know if I can adapt the engine of a Toyota Tercel to a Toyota Celica. Recall that the celica engine is longitudinal (trcera traction) and the tercel is transverse (front traction) .... any data or experience they could have serves me ......
14 years 7 months before #20813 by manual-mecanica
Manual-Mecanica response on the re: helps with the modification of an engine
Of power you can, the problem will be the cost, in addition the celica has 2.0 engine, and those of the tercel depending if it is 2e, 3e or 5e bain up to 1.5, for Ke Kieres lower the engine?, the adaptation can be enhance Correct functioning, everything can be done the problem is that sometimes it is little profitable luck and anything consults, Toyo is easy to handle and repair is a good weekend project hahaha but a bit expensive.
