An aid for a rookie.
14 years 7 months before #20775 by manual-mecanica
An aid for a rookie. Posted by manual-mecanica
Someone could advise me to do a retro cat mod 416D, I did the engine service and take the pump to laboratory. It starts but only for 5 min, the only fault is that it turns off does not slice or anything like that stable style only goes out. Thank you very much for your support.
14 years 7 months before #20803 by manual-mecanica
Manual-Mecanica response on the Re: an aid for a rookie.
Hello, control in the fuel entrance that does not happen with air, it is very possible that you are happening to you that changed the hoses in transparent ones to be able to see the passage of fuel greetings
14 years 7 months before #20804 by manual-mecanica
I had a problem with a Komatsu retro, with the same symptom, we repaired the engine, the injection system, and the problem was the servotransmission that overloaded and brakes the engine.
