Load problems towards the D-Max 4x4 3.0 battery
14 years 7 months before #20762 by manual-mecanica
Manual-Mecanica Response on the Re: Cargo Problems to the D-Max 4x4 3.0 battery
The registered load does not work for you and without marks marks 14 that means that the voltage is fine but if you place the overgrows and go down that way that says that the rotor is clear that is to see where you placed the voltimeter if in the battery or in the alternator because to diagnose it well it is time to place it first in the alternator usually marks 14 to 14.5 now place the overload. MINIMUM IN THE ALTERNATOR I MUST MARTS 13.9.8 IF THE ROTOR MARTS YOU IS READY AND IT IS BETTER BUY A COMPLETE ALTERNATOR
14 years 7 months before #20767 by manual-mecanica
Good night, check the lands or masses of the battery to the cabin and chassis engine, this happened to me in a dmax that the client changed the battery being good and the vehicle seems to be the low battery of load
14 years 7 months before #20770 by manual-mecanica
you tell me where they are ???
14 years 7 months before #20771 by manual-mecanica
The alternator took it out and tried it outside the camoneta and everything indicated that it is fine .... I will try to try it with another alternator .... You know where I can carry my truck to do that test, and if it works when trying with another alternator I change it right away.
Thank you very much for your advice.
14 years 7 months before #20778 by manual-mecanica
If you have these voltage variations, try the diodes of the diodes plates, previously desoldala del stator and then measures diode by diode and the value must be even for all, otherwise it replaces the portadio platelet
