Patch for clip V97. . .
14 years 8 months before #20647 by manual-mecanica
Patch for clip V97. . . Posted by manual-mecanica
I have the Renault Clip V97 software but I need a patch to be able to run it when installed. . . Please if there is someone who is in the subject, I would appreciate your advice
thanks
14 years 8 months before #20664 by manual-mecanica
Manual-Mecanica Response on the Re: Patch for clip V97. . .
Good morning,
if what you want is to install the Renault Clip software, you must do the following:
Create a text file with Microsoft Notepad or Wordpad with the name clip containing the following information:
HKEY_LOCAL_MACHIN [HKey_local_machine \ software \ sagem sa \ plate-form]
"expert" = "0"
"produit" = "inconnu"
"version_bios" = ""
"configouoro" = "1.07.00.00"
"verse" = "4.02.01"
Then, rename the file so that the extension is. .txt)
Execute the created file and you can install your clip.
Note: It only works under Microsoft Windows XP.
Greetings,
14 years 7 months before #20839 by manual-mecanica
All clear to rename the file. . . ? How is it done? And once I do I have to hit the clip folder?
Thanks for your time, I have a breakdown in my Renault and they ask me many $$$
14 years 7 months before #20866 by manual-mecanica
If that patch works but what you need to repair since you can not program must recognize and sign itares of the original Marce team recorded in the France., Can you only diagnose. Tell me what is your problem?
14 years 7 months before #20898 by manual-mecanica
This is what I want to diagnose, with that at the moment I am satisfied. . . An injector fails me and I would like to know what it is. . . I have the manual, the book of codes of Averia I only need to activate it, since the cable takes it to me from a "Friend workshop". . .
