4x4 for explorer 1992 activation problem
14 years 1 month before #27547 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with 4x4 For Explorer 1992
Well,
the procedure that I follow is the following
1- I got the electrical diagrams of the Transfer Ford Explorer 1992
2- Verify that none of the components is missing (components of function of the transfer box)
3- The truck has in the rear wing LED is running
--- In the event that this LED is paid, the controller resets (it has a white button on the side) when you review it will turn on the LED
--- you turn on the engine you put in neutral and 0 k/h oppress the 4x4 button if your LED goes out then you have a high current and your controller is protected.
In my case, what I did was hit with a small hammer to the engine that is in the Tranfer box and with that it had (in my case it was recommended to replace it was motor) but even it is working with a spot that fails again I will change it.
Well, I add the diagrams if you have a problem or it is something else you tell me
--- In the diagrams come the real colors of the
curiosity wiring where you are?
I hope this information serves you.
14 years 1 month before #27617 by manual-mecanica
Thank you very much for your Respuets to Ferdav, Yosoy de Santa Cruz Bolivia. BUENO Check the 4x4 controller and the LED lights, check the mechanical part and it turns out that the engine was failing, Ice some internal repairs, and I tell you that the button that says (4x4) works, active and deactivates, but the one that says (Low Range) does not turn on or activate the engine. What do you think is the problem?
14 years 1 month before #27618 by manual-mecanica
By the way Fradv where I downloaded the manuals that you attached? Thank you very much
14 years 1 month before #27619 by manual-mecanica
Oh conditions for the activation of the Low Range
1-Configure your
2-Pones in neutral
3- The speed must be 0 k/
4- Active The PB that says 4x4 Asta that the indicator indicator
5- is turned on. Since aya on the 4x4 oppress LED the Low Range PB will turn on the LED LOW RANGE Indicator LED (listen to some "grinding" transfer)
and ready to use your explorer in Low
des Activation mode of Low Range
1-Pase in neutral
2-steel at 0 k/h
3-oprimes The Low Range PB will deactivate this mode (the indicator LED will turn off)
4-OPRIMes The 4x4 PB (the 4x4 indicator indicator LED will
be
deactivated I got them in the wave
14 years 1 month before #27630 by manual-mecanica
Ferdav again thank you very much for the explanation if I have more problems I hope to continue consulting you since it shows that you know about the subject. Greetings
