4x4 for explorer 1992 activation problem
14 years 8 months before #20478 by manual-mecanica
4x4 for explorer 1992 activation problem published by Manual-Mecanica
Hello, I have a problem with the 4x4 activation of my for explorer
- I oppress the Low Range button and there is no change in anything (the indicator LED does not turn on)
change
in anything (the 4x4 indicator does not
turn Someone has the electrical diagram of the 4x4 module that could provide me
or some tip to eliminate this module
and leave with Swish the 4x4 system
appreciated any imformassion
thanks.
14 years 7 months before #21132 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with 4x4 For Explorer 1992
problem solved
14 years 1 month before #27455 by manual-mecanica
Hi Ferdav, I'm new in this forum and I found your problem solved.
I have a Ford 92 wagon and I have that same problem. I wanted to know if you can give me some help or explain how you solved it. I appreciate your help.
14 years 1 month before #27545 by manual-mecanica
Well,
the procedure that I follow is the following
1- I got the electrical diagrams of the Transfer Ford Explorer 1992
2- Verify that none of the components is missing (components of function of the transfer box)
3- The truck has in the rear wing LED is running
--- In the event that this LED is paid, the controller resets (it has a white button on the side) when you review it will turn on the LED
--- you turn on the engine you put in neutral and 0 k/h oppress the 4x4 button if your LED goes out then you have a high current and your controller is protected.
In my case, what I did was hit with a small hammer to the engine that is in the Tranfer box and with that it had (in my case it was recommended to replace it was motor) but even it is working with a spot that fails again I will change it.
Well, I add the diagrams if you have a problem or it is something else you tell me
--- In the diagrams come the real colors of the
curiosity wiring where you are?
I hope this information serves you.
14 years 1 month before #27546 by manual-mecanica
Well,
