Help injector problems
14 years 8 months before #20267 by manual-mecanica
Help injector problems posted by Manual-Mecanica
Hello everyone, I hope you can help me, I have a problem with my MK2 Model 91 golf, the engine and head are reproached, it had to be completely disassemble How much I turn on the key, the injectors begin to inject fuel, but they do not stop doing it, in advance I appreciate their help the fuel system it brings is the Digifant.
I await your answers, because Eme is urgent to start it
in advance thanks ...
greetings ...
14 years 8 months before #20272 by manual-mecanica
Manual-Mecanica response on the Re: Help injectors problems
Hello, in the Digifant system, the injectors are simultaneously operated through Pin 12 of the motor controller (for the year you describe should be the coffee cable) Chekea that this circuit is not referred to mass, with the injuries and connector of the ECU disconnected, then if it is thus repaired the wiring, if it does not connect the injuries one by one and verify the above. If you have no test results with another ECU Motor, greetings from Chile.
14 years 8 months before #20278 by manual-mecanica
I already check the wiring as you tell me, but everything is fine, today I got another ECU, tomorrow I connect it and I tell you how it went
thanks for your answer
greetings ....
14 years 8 months before #20294 by manual-mecanica
HELLO. What you can do to test if it is the ECU is with a 12V LED in the injector connector if the light flashes the negative pulses of the ECU would be fine if you were stuck you would have to change the ECU. GREETINGS
