How is IAC valve from Pointer
14 years 8 months before #20253 by manual-mecanica
How is Pointer Valvula IAC published by Manual-Mecanica
Hello, friends I have a fault that apparently is the IAC valve someone knows how I can calibrate it before putting the new one. Thanks for your answers
14 years 7 months before #21157 by manual-mecanica
Manual-Mecanica Response on the topic Re: As is calibrates IAC of Pointer
Get the original valve Magneti Marelli you install it, you open your swicht waiting for a few seconds and you turn on the engine with that enough I hope it serves you. Note other valve brands do not work correctly greetings
