Antifreeze liquid change
14 years 8 months before #20213 by manual-mecanica
antifreeze liquid change published by manual-mecanica
Hello good I have an astra g a 1.7 cdti of 2004 I just changed the thermostat and and threw antifreeze. But my question is, how is the antifreeze liquid changed by Done is empty where it is filled? If you have to purge it? And where? M have said that some that have the engine running is filled by a maguito and it is not afraid to break it. It would greatly say that they would say thank you very much.
14 years 8 months before #20216 by manual-mecanica
Manual-Mecanica Response on the Re: Antifreeze Liquid Change
Refrigeration system - Fill and purge
J635000
Check / check Visually
1. Use only antifreeze 19 40 650/9194431 (red) and guarantee a 50% water concentration and 50% antifreeze. The antifreeze not only serves to prevent the cooling system from freezing, but also protects all components against corrosion and lime deposits. Therefore, the addition of antifreeze even in countries with warm or tropical climate should not be renounced.
2. In addition to the mixing ratio, water quality also plays an important role. Drinking water normally meets these demands. Regenerated seawater does not have sufficient quality!
3. Motor damage can also occur by an unauthorized antifreeze!
4. If the radiator, cylinder head or the butt joint have been replaced, the used cooling fluid should not be used again!
IMPORTANT: Air conditioning vehicles: Disconnect the air conditioning installation or put in ECO mode with ECC
5.
Open the
Refrigeration System
: The cooling system is under pressure . of the refrigerant expansion tank
8. Put the engine running and let it warm rolling
• Let the engine heat up to 2500 rpm maximum, until the 1st speed of the radiator fan speed is connected
9. Purge the cooling system
• Let the engine work for approx. 2 minutes between 2000 and 2500 rpm
Note: For this, the air in the cooling system is separated through the degasification pipes
10. Stop the engine and let it cool
11. Check the level of the refrigerant and, if necessary, fill the refrigerant to the "KALT/COLD" brand
