How would I like to help me thanks
14 years 8 months before #20261 by manual-mecanica
Manual-Mecanica Answer on the Re: how would I want them to help me thanks
Hi Bonice turned on the frontier but look how weird the CKP replaces and turned on the hard engine 15 minutes on but turned off and did not turn on again
14 years 8 months before #20262 by manual-mecanica
Hello in relation to the Caravan I am almost certain that the problem you have with the CKP, because the strategy of Jeep Chrysler Dodge, etc Coils and much less will activate the pump, quickly see if the computer is seeing crankshaft turn is to start and in the data flow of the scan see if there is RPM. The following if there is no RPM is to go to the rotation sensor and measure the signal with an oscilloscope to see what is seen. In these cars they work normally with 8 or 5V depending on the model. In relation to the Frontier, that fault is very rare let the manual check the weekend and warn you, for now check connectors and cables because you had initially told me that there was an injection pulse but it does not spark, and if there is a pulse it is because the computer is seeing crankshaft turn. I am attentive to your comments greetings.
14 years 8 months before #20265 by manual-mecanica
Ok thank you very much but the most that intrigues me is that the frontier turns and tries to turn on but does not turn on since the mixture is rich to take out a spark spark spark and was completely wet with gasoline now if there is a spark in the spark plugs and coils but tries to turn on but turns out very fast since the mixture is bn rica
