How would I like to help me thanks
14 years 8 months before #20160 by manual-mecanica
how would I like them to help me, published by Manual-Mecanica
I am working a 2005 frontier 4.0l and does not turn on the engine does not throw DTC and there is no spark in the coils but in the injectors there is pulsation that is because friends thanks
14 years 8 months before #20176 by manual-mecanica
Manual-Mecanica Answer on the Re: how would I want them to help me thanks
Hello good morning, check if there are 12 volts in the coils, forget about the CKP because there are injection pulses. If there are no 12 volts check fuse. Attentive to your comments
14 years 8 months before #20177 by manual-mecanica
Ok I will verify if there are then the 12 volts in the coils but there is any possibility that the 6 coils or the pedal tps and the TSP Throtle Body have been damaged, is it out of synconation?
14 years 8 months before #20178 by manual-mecanica
And thank you very much bonice
14 years 8 months before #20179 by manual-mecanica
If you had problems with TPS or APP potentiometers, you would have some fault code, it is difficult for coils to all be damaged at the same time I think the problem has it in the food of the coils in the 12 volts that must reach it. I am attentive to your comments greetings.
