Ford Ranger ignition problem
14 years 8 months before - 14 years 8 months before #20003 by manual-mecanica
Ford Ranger ignition problem published by Manual-Mecanica
Hello everyone, I have a problem with a 4x4 Motor 3.0 V6 year 99 does not turn on checking the injector pulse and it is well arrives current, the gasoline pump, the Camshaf sensor and the cranshat sensor are changed and nothing was tuned to change oil filters ect. It does not throw failures in the scanner the only thing that when I give it to the key throws a light that blinks red color that says Theft the car has an original key they tell me that it can be the transfording chip the truth I do not know of that I would like to know what I can do, I have crazy I already changed it, I change the ignition. The alternator is already checked, starter engine I would like to know what I can do or how can I eliminate the problem of the supposed chip so that it ignites normal or that they advise me because I have no experience in that please help me :(
Last edition: 14 years 8 months before by .
14 years 8 months before #20020 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Ranger ignition problem
Net that you bring the problem well crossed, I hope that my advice is useful, your problem is that the anti-theft is activated, this means anti-the robbe Original computer. The only solution to this problem is to reprogram the numerical combination in the computer memory and the combination of the ignition key this is achieved only connecting the specialized scanner for these cases. Those who handle this type of scanner are the locksmiths and they use this tool to program the combination of the new keys that contain chip, I recommend you consult with some that adequately guide you. Greetings and good luck. Respond when you find the problem to find out about the solution.
14 years 8 months before #20039 by manual-mecanica
Hello, try, leave it in contact 2 hours so the Transport of the key is programmed if it is not possible that the same transport does not serve must change the transport that is TP 02 model and program with an OBD2MAX SCAner Greetings Greetings
14 years 8 months before #20045 by manual-mecanica
Good colleague you can also program it with a SJ4 scanner you get in Ford and you give it to programming of keys, another check that are connected the cables that are devounces from the board leave the cylinder of the Swiss, and final
