Pump injection 306 1.9 td lucas brand
14 years 9 months before #19981 by manual-mecanica
Pump injection 306 1.9 TD brand lucas posted by manual-mecanica
Someone can tell me if the distribution gear that the OIL gas pump activates has only one blocking position.
to in the inertia steering wheel in addition to the two M 8 x 1.25 screw
14 years 9 months before #20063 by manual-mecanica
Manual-Mecanica Response on the Re: Injection Pump 306 1.9 TD Lucas brand
Hello, you will see the first one that you have to whittle is the crankshaft and then the tree, but the procedure of truth is before the upper dead point as a 6 degrees give it a mm of preload, greetings
14 years 8 months before #20149 by manual-mecanica
Hello moth, thanks for the data, in reality the last thing is not very clear to me, it is only enough for me to know that once the blockade of the inertia steering wheel is obtained, the bloc of the dentated pulley of the injection pump is automatically determined.
All the best
14 years 8 months before #20151 by manual-mecanica
Hello Alfajor. Once you have the crankshaft block, you have to enter perfectly the two M8x125 screws that have the pump pulley. Leave them well anchored and you can already remove the pump without having to remove the distribution or remove the tension from the belt. If you have doubts about the status of the distribution strap, better change it in time, then regret.
I hope this will this will.
14 years 8 months before #20184 by manual-mecanica
Hello, I am with podasetos 71 you can remove without removing the tension, it carries two 6mm screws to leave the pinion and strain the pump, you will see what I tell you previously is that just behind the pump wears a screw where the pump precariousness comparator is installed, but if you have it that the firefighter Sila takes to repair the block in the position of preload and your engine is enough. MOARDS ALREADY COMBUSTION GREETINGS
