MAZDA 323 HS
14 years 9 months before #19435 by manual-mecanica
MAZDA 323 HS Published by Manual-Mecanica
My mazda does not hold in minimal they have done everything and could not be solved, poet someone who gives me a possible solution. Mod 96
14 years 9 months before #19452 by manual-mecanica
Manual-Mecanica Answer on the Re: Mazda 323 hs
How is the failure, is it injection or carburetor, only fails or turns off, when the fault feels? What steps have you taken to try to correct the fault.
14 years 9 months before #19518 by manual-mecanica
The fault consists that when it is cold you have to step on the accelerator so that it is held, as when it is hot, at all times the accelerator must be treading because otherwise it goes out; The car is carburetor, the car is but constantly accelerating goes out, it does not give minimal. To correct the fault, the carburetor has been lowered to clean, it has been changed packing has been calibrated gasoline level and has been fixed but after two days it continues for it. I don't know what to do...
