Radiator fan
14 years 9 months before #19142 by manual-mecanica
Radiator fan published by Manual-Mecanica
Good morning,
I need to make the following query, the temperature bulb has a moment, therefore the ventilation stopped working, so I made a kind of bridge with the intention that the fan does not stop working and thus prevent the engine from hot too. Then I need to know if that harms the use of the vehicle. As the car will be a bit cold because the temperature now indicates less than normal, can this cause more fuel?
greetings
14 years 9 months before #19146 by manual-mecanica
Manual-Mecanica Response on the Re: Radiator Fan
Of course and that will be the most importing consequence because the computer will always seek to take the vehicle at its normal operation of operation, therefore you will be sending more gasoline. Not knowing the details of the vehicle yet, you can also turn on the witness of Averìa and the code is thermostat failure ....... greetings
14 years 9 months before #19161 by manual-mecanica
Thank you very much, I will immediately make the bulb change
