Gelatinous fluid similar to the mahonesa in cap
14 years 9 months before #19062 by manual-mecanica
:( Hello, someone could explain to me why a gelatinous fluid appears like the Mohonese in the plug of the oil and rod filling of the level, the car is a Volkswagen New Beetle 1.6 2007 gasoline with 54,000km thanks in advance.
14 years 9 months before #19066 by manual-mecanica
Friend I have an unfortunate news, water is passed to the oil so you will have to take out the cylinder head, change packaging, see if you have to rectify butt see how this vila and bench metals, also see the valve seals, that in general.
greetings.
14 years 9 months before #19088 by manual-mecanica
Thank you for the imformation, you leave me dusty, I will have to think about putting it in workshop, they value it and give me a budget, that you slaughter and take care of the car that can happen, it will be a factory failure.
14 years 9 months before #19116 by manual-mecanica
Let's see can other things are not always the cylinder head, the first thing is to know if the engine has been heated, if you have uploaded the oil level a lot, if you have circulated a lot with the car like this, go to a trustworth
14 years 9 months before #19120 by manual-mecanica
I regret your case and it is not easy or cheap. The same thing happened to you happened to me and it came out in good money. They had to rectify the motor heads and replace it (change the joint). And to my misfortune even so it was, because they told me that I had a fissure in the monoblock (due to a warm that my car had). So what they did was wash the entire engine and poured a magical liquid called Metal Seal. This liquid does is get into every fissure that there is and seal internally. My car was as new and then I honestly sold it immediately because one more expense would be my ruin since I put almost 20 thousand pesos for repair. LUCK!!
