Neon 2000
15 years 3 weeks before #17113 by manual-mecanica
NEON 2000 Published by Manual-Mecanica
Hello, I hope you can give me an opinion
I have a Dodge Neon 2000 a year ago it takes away the thermostat because I was stuck and originated that it would warm up at least that marked the board. Currently the car is very fast consumer the water or antifreeze does not have any leaks yet the water storage where it is stuffed a lot and continues with the consumption of water, to believe that it should be
appreciated by their opinion or diagnosis.
14 years 11 months before #18119 by manual-mecanica
Manual-Mecanica Answer on the Re: Neon 2000
Hello, I hope to help you, usually the electro starts when the water temperature is about to ervir, the steam prior to that, is what you are taking and make you lower the water level, the ideal would be that you get a sensor that starts and cut more under the electro, it is in the radiator and records the temperature to start the electro wants you have to put the one of the other car. same problem I hope this is a hug lucky
14 years 11 months before #18238 by manual-mecanica
Hello, you will see in this case we would have to study if you have any cylinder head, so I have been able to understand.
You will see the radiator's plug in cold. . I hope it is not like that
greetings
