Renault Scenic 2 (spend the control battery)
15 years 1 month before #17065 by manual-mecanica
Renault Scenic 2 (Spend the command battery) published by Manual-Mecanica
Hello, I am new in the forum, I have a problem with the centralized closure of my Scenic 2, the command was not able to open and close the car, but I changed the battery and worked again, at approximately 2 weeks the opening and closure with the remote control began to fail again, I changed the stack for the second time and operated again, I have changed the battery 3 times in a month.
What is that battery expense due to command?
15 years 1 month before #17075 by manual-mecanica
Manual-Mecanica response on the RE: Renault Scenic 2 (spend the control stack)
Most likely, K has a contact, go to the Renault and they look at you, it costs you anything.
And as a second hypothesis, it may be K command, you leave it somewhere in the K is constantly pressing some control button.
15 years 3 weeks before #17171 by manual-mecanica
thank you so much
