Ralenti valve
13 years 10 months before #24594 by manual-mecanica
Manual-Mecanica Answer on the Re: Ralenti Valve
It seems to me that the problem could be dirty injectors the one that works well in cold is because the system works open as normal while taking temperature the engine for the computer works (closed system) ... Maybe that is lucky
13 years 10 months before #24595 by manual-mecanica
Friend, to clean it, use the WD40 that is magical, make sure to clean each little hole and then in fact the contact cleaner to remove the WD40 and I remain as new, do not worry there are no special considerations, just be careful that some screw falls inside the admission or something like that
13 years 10 months before #24604 by manual-mecanica
Ok, I mean that I first give it WD-40 and then the clean contacts, of the accelerator cable you have not told me anything to remove it, to see if I am racked and then the mess, hehehehe.
13 years 10 months before #24613 by manual-mecanica
Hahaha you have to open the butterfly or the throttle side of the Obio motor side, to the stop, and then retire to the Sueva side does not entertain excessive force is not neseous.
13 years 10 months before #24617 by manual-mecanica
Let's see male what amou clumsy, with the butterfly open, do you refer to rotating it as if you will accelerate to bring the cable out of your compartment? Is that? I tell you that I am a bit Negao, I need the explanations to the poor, hahahaha.
