Ralenti valve
13 years 11 months before #23853 by manual-mecanica
Ralenti valve published by Manual-Mecanica
Hello everyone. I have a 106 that lately as soon as it starts it is covered alone, the revolutions oscillate a lot, as I understand it could be the idle valve. Thank you so much.
13 years 11 months before #23871 by manual-mecanica
Manual-Mecanica Answer on the Re: Ralenti Valve
It is located in the body of the admission, I recommend that you take out the full body are 4 10 mm screws, you release the accelerator cable and take out the air hose, the one that comes from the filter. You take out you, everything usually happens to them, I have done it many times with this model, but clean the full body to have an optimal result. And do not scare yourself is not complicated at all
13 years 11 months before #23876 by manual-mecanica
Thanks Kikemec, I mean that I take the whole body instead of only the valve, and to clean it well they commented with a product to clean circuits is correct? or I can use something else. A greeting.
13 years 11 months before #23877 by manual-mecanica
Hello:
The Renault Megane Sporway 2.0 also gives the same problem (unstable RPM in idle), being similar Peugeot and Renault The indications are the same
when the problem occurs at 2,500 rpm (it does not maintain RPM, it accelerates or decelerates), what is the fault?
13 years 11 months before #23891 by manual-mecanica
Look to clean the body of the admission I use diluent Duco, and for the valve itself a clean contact, because the Duco is very strong
