Such you see, you already solved the problem, you commented that it was the second pioblema in six months, what problems did you have before?, did you tell a blue blow and smoke, I do not think that a blue smoke vote vote due Cylinders because not everyone has the same compression pressure, another to check if the valves are Hermeticized the camera, only oil is added to the cylinder and the compression pressure is measure Malographed, or the Board of the Curate or Head is not sealing or has broken fissures due to excessive overheating, a question How long did you repair your engine?, brother if you already solved your problem congratulations, but if you are in process, luck, keep these comments in mind these comments
